mberliner1626
- Sep 17, 2009
- 28
I posted about this boat in the engine section at first... now it looks like I'll be doing a little more work than expected, no biggie. Got the boat for nothing, enjoy the work.
The old 305 has been pulled out and will be replaced with a 350 merc when this other work is done.
Attached are some photos of what I have found.
There needs to be some cleaning done, but you can see the split in the motor mounts. Not so sure how to handle this yet. I'm going to clean up everything so I can get a better look at it.
Also look, the stringers don't go all the way to the transom? They are not attached. It looks original? Does this make sense? Should I leave it as is? Or cut it back, clean it up and run them up the transom?
I also pulled up the rear fuel cover and found... NO TANK! Didn't expect this! I did pull the cover on the front tank and it is there. I called Phil at Alloy metal works in Farmingdale NY and he can make up the tank, he has the plans. He quoted me what seems to be a fair price, but I'll shop around a little bit.
Except for some slime, dirt and grit the compartment seems to be in ok shape, solid (I knocked on it) all around (a good cleaning will show the truth). Except for the wall between the rear fuel tank compartment and the bilge... rotted wood. My question is should I cut out entire wall and replace? Or cut out the rotted ply between and keep the fiberglass and fill it?
Here are the split motor mounts, in the corner of the blocks.
Here is where the stringers don't touch the transom.
