I have a Mercruiser 4.3L I'm having an issue with my boat not wanting to start after its been running for a while. It starts fine at first, but then after I've been running for a while and I go to re-start it doesn't want to unless I use the throttle only, but then as I go back into nuetral to engage the prop it dies? I had to turn the idle on the carb up to about 1300 to keep it from dying just so I could engage the prop to make it back to the launch ramp! Any ideas? No water in oil, engine was just rebuilt.
