Yamaha 5Hp 2-stroke problem with WOT
mateomapett
Hi,
I' am new here, and I need your help with my Yamaha 5 Hp, 2-stroke. Motor has poor performance, it can reach only 3600 RPM-s. I cheched reed valve and cleaned the carburator but nothing has changed, what else should I do
99yam40
Re: Yamaha 5Hp 2-stroke problem with WOT
Make sure timing is advancing properly and is in spec
How are you measuring RPMs? could be you are not getting correct reading
Could be too much prop and overloading motor
mateomapett
Hi,
I measured RPM-s with inductive digital tachometer, the engine was submerged in a water tank and in neutral. I will check timing but seems to me that timing can not be adjusted? Motor starts and run normal up to 50% of throttle but when further enhances the throttle, the engine is choking and from carburetor can be seen spraying (like fog). What if the timing is not advancing properly?
99yam40
Look at your service manual and see what the specs are and how to make sure it is advancing properly.
You should not be running any motor at WOT in neutral
I do not trust those tachs to give accurate RPM readings
