Looking for some ideas. I am new to boat ownership, so I bought myself a 1978 Sylvan Sportsman 16' V-Bottom Aluminum fishing boat with a 75hp Johnson Stinger. Boat is in great shape so I thought it would be a nice first boat for me and my young family. Took the boat out a few times after purchase and had problems starting and had a hard time to keep it running. Motor would die at idle and when putting into gear, but once you kept it running and got to full throttle, the boat got out of the water quick and moved really good. It would run well over 6000 rpm's. Since then we have put in new plugs, cleaned and rebuilt carbs, added a bottle of seafoam to the tank to run through the motor, tried different sizes of jets, put a new prop on to bring down the rpm's (went from a 17 pitch that was on it to a 19 pitch), and replaced batteries. After all of this my starting issues have gone away and my dieing issue has gotten better. My problem now, I have no power. At full throttle I am only getting 1600 to 1800 rpm's and I can't go any faster than trolling speed. When I take the cover off the motor I seem to have a lot of gas and oil that is not burning up. I have had some suggestions of bad coils (mine don't look burnt and seem to have been replaced recently), a new stater (how would i test if mine is bad before i spend $207 for a new one), plugged exhaust, low compresion (mine measures 105 to 110).
I have called some boat mechanics in my area and most of them do not work on motors of that age. So it looks like I'm going at this alone.
Any suggestions would be greatly appreciated.
