wiring diagram 20 yr old 50 merc.
mowermack
I just purchased a 28 ft. pontoon and am having trouble getting spark. Where can I find a wiring diagram for this motor?
Zenvalo
Re: wiring diagram 20 yr old 50 merc.
I'm fairly new here, so I don't have an answer to your question, but neither will anyone else. The only response you'll get will be asking for more details. People will want serial numbers etc to verify the year of the motor and likely you will need a manual to find the specific answer you're looking for.
mowermack
I have more information it's a 500 thunderbolt 50 ser. no. 3478205 possible 1972 year.
Zenvalo
Your motor is in fact a 1973. '73s serial number range is 3478003 - 3816307. I have a '73 Thunderbolt 500 also, but haven't had any issue with spark as of yet. I've done a fair amount of reading lately on here as mine is not currently "up to par" and there are other possibilities aside from wiring. Hopefully someone chimes in and can let you know what order to troubleshoot in. Otherwise, if you search around the forum, there are threads with the same issue. They might be a different motor i.e. Thunderbolt 650, Thunderbolt 800 etc, but the trouble shooting will be pretty much the same.
