Re: Astro 18fsx wiring diagram
Step 1 - Determine which wire is which with a multi meter or with a 12V probe (I prefer a multi meter)
See what is hot all the time or if they work off a key switch
You might have to run a new set of wires to get a clean connection (W/O any interference to the new DF)
Be sure to run this through (Or add) a fuse.
There probably is not a wiring diagram specific to your boat since many are wired with options at the dealerships. I will move this to the electronics section. There are generic diagrams here.
