Hey guys, I just installed new shift cable which apparently works too well. The new cable slides so easily that there is not enough tension to move the v-block thus engaging the ESA. My soultion was to "spring" the v-block spring reducing the pressure exerted on the v-block. This worked fine in the driveway but nice and hot on the water.... the v-block moves so easily that unless the exact postion is hit with the shifter going to nuetral, the v-block engages ESA which killed the engine yesterday as the idle was set too low.<br /><br />Any suggestions would be appreciated.<br />Thanks, Greg
