From all of the reading I can find online about props., and the proper ones, and pitch, diameter, etc.... here is a question that came to me. I run this 18ft SeaRay with the 135 v-6. The standard prop that came on the boat was the 19pitch, 14 3/4 inch stainless prop. I also have used a 17 pitch aluminum and like the hole shot better with that for skiing. But that prop is a little smaller in diameter, and doesnt' hold the water well in corners and rough water. (the stainless is a little better, but not perfect) My question is this,, because everybody says an aluminum prop flexes under load, (actually changes the pitch as it does) would I get a better hole shot from an aluminum 19 pitch than my stainless? If so, then would I maintain my top end speed (within reason) and rpm range at WOT? <br /><br />And for everybody that wants RPM's, here they are,,<br />19 pitch stainless WOT runs 5200 RPM<br />17 pitch aluminum WOT runs 5800 RPM<br /><br />Also, any thoughts on 4 blade or the new "Ballistic" props on the market?<br /><br />thanks again,,<br />
