cashmannsdq
- Jun 19, 2011
- 2
Last weekend our Stringray 220sx overheated. Gauge was all over the place so I shut her down when the alarm came on and got towed back to the slip. We pulled the thermostat and replaced with a new one which we believed to be the problem (impeller changed last fall).
We took her out again today, keeping at about 3,000 RPM for a nice cruise. I was fixated on the temp gauge the whole time as it rose to 180 and would trigger the thermostat and fall back. This went on for a while and then she spiked to 200 and the alarm followed. I pulled her to neutral and the temp went down - was able to get back to the slip at around 1,000 rpm.
Called the mechanic on duty and explained what had happened - immediate response was the impeller.
While I am not scared to replace another impeller, I would like some experience if you would to see if anyone has had similiar issues. When I opened the engine compartment, the left side of the engine, along with the water hoses was cool to the touch, however the right side was hot (not so hot that you could not keep your palm on it).
It seems to me that water is getting to the left side very well, however the left side (appears the hose is going through the thermostat housing) is either restricted or not being pumped through.
Is there a sea pump on the front of the engine that might have gone bad or is the only impeller located in the lower unit?
Thanks much!
Thanks much!
