1998 ski supreme
hoppe
I am getting excessive water on the drivers side of the boat. Even after a week in the garage, carpet still soaked. Curious if someone could point me in the right direction to resolving this? Just want to be sure this isnt a problem with a cooling system...
Re: 1998 ski supreme
Ayuh,... Welcome Aboard,... The trouble with water leaks, is the only way to find it is,.... LOOK...
You Find it,.... 'n We'll help ya fix it...
bmdupont
I have 98 supreme 210 medalist, the boat has always been heavier on the driver side and i suspected it was from water coming in.
At one time I pulled the backseat and as water splashed over the back it would come in along the seam. Only when a wake would splash over though.
Do you notice your boat being heavy on the driver side? I wakeboard and it creates an uneven wake, it took me 6-70lb sand bags along the passenger side to even it out. I tried re-calking that seam and it hasnt solved my problem.
Curious what engine do you have?
