Re: what happens after dropping 2 sizes in pitch?
Well, the hole shot was never an issue with the 21" pitch. It was always pretty quick, and pulled me at 180 lbs. up on 1 ski with no problem. I didn't ski with the 17" pitch, but I can only imagine it will be better all the way around. On top end speed, I lost about 8 mph, topping out at 50. With the 21" pitch, I could get up to about 58-59, but the boat would start to "chine walk" and I don't like that. I would do it just to get the rpms up, but that would only be for about 30 seconds and then I would back off before losing control. But even at that, I could barely get the rpms up to 5000-5100, with just me in the boat. The 17" SS prop I used was a loaner prop from our boatyard. I returned it today and gave them my findings and also told them I'd like to switch to an aluminum prop. They recommended a 14.5 x 19" pitch aluminum, which I purchased. The mechanic said the 19" aluminum prop should easily get me within the WOT range; the boat goes back in the water Friday, so I'll find out then. I'd rather use an aluminum for price and safety--if I hit a rock, I'd rather ruin a prop than the entire gearcase. Any comments / recommendations you have would be much appreciated. Thanks again.
John
