I have twin 1991 454's. One engine lacks power and will not achieve RPM. Starboard engine idles fine but does not sound as crisp as the other. When accelerating with both controls the same port is at normal 3200 rpm starboard will only run at 2700 rpm. WOT will only run at 3300 RPM. What I have done: Installed new plugs, wires, cap and rotor. Changed cartridge fuel filter and bulk head filter. Rebuilt carburetor (Quadrajet). I have the ability to switch tanks so I ran both engines off of the port tank with no change. Engine starts fine and does not miss. Linkage does open up all the way and the choke is ok.It acts like it does not get enough fuel.
