Thank you, for replying. The problem is that the drive assembly was stuck in the down position and wouldn't engage the fly wheel during start up. I did some knocking on the starter body and it engaged fine. I did some more research and am planning on lubricating the drive assembly (WD40?). If that doesn't do the trick I'd replace the drive assembly.
