90 yamaha 115 etxd stalls at idle and runs rough at low rpm
Robo74
I have a 1990 Yamaha 115
etxd that seems to be starving for fuel at idle and low rpm.. it will run better if u tap the electric choke constantly until it gets above 2300 rpm and it will run great.. carbs have been cleaned and primer bulb changed
Capt Ken
Re: 90 yamaha 115 etxd stalls at idle and runs rough at low rpm
Cleaned by who? What you describe is still a low speed mixture problem usually from dirty jets. I see carbs that was suppose to be clean all the time that was still clogged.
Robo74
Cleaned and rebuilt kit installed by a Yamaha shop the first time which lasted a short time then I cleaned them which lasted a short time... and I mean by short time like one day on the water and the next is right back to running correct... I checked the filter and pump for trash or a bad diaphragm
