new here. I have a 1992 Sea Sprite with a 4.3 v-6 4 barrel carb. My engine started running really bad after I did an oil change on it. It will not idle, backfires thru the carb and stalls out. I changed the plugs, wires, cap and rotor, Checked the timming and it was spot on. I changed the water seperator, and the fuel filter neither had evidence of water in them. Can changing the oil produce such drastic running condition? Anything else I should be checking for?
Thank you for any help
