Hello All,
Having some weird symptoms hopefully someone can help out with:
- engine buzzer came on with a low buzz and now runs full time when engine is started. Oil and water gauges all show good and engine runs fine.
- dash lights are on (low, not at full brightness when key is off)
- yesterday i turned the key off after cruising for about 20 mins at low speed and the engine kept running....not idled on for a few minutes knocking, but kept running full tilt with dash lights still on when key was completely out.
Already tried replacing the ignition switch (same sypmtoms so put the old one back in). Tried moving all cables around under the dash and near fuse box to see if I could get dim dash lights to turn off but no dice.
thoughts??
big mahalos (thanks in Hawaiian!)
Vinnie in HI
thoughts??
Vinnie in HI
