grappler05
- Jul 19, 2012
- 2
I have a 76' evinrude 25hp and about 2 months ago i was having issues with the engine at higher rpms. At higher speeds it was slipping out of gear and slamming back in, making a banging noise and eventually breaking a drive pin. When i let the oil out there was mostly water with about 1/3 oil. Not very much metal flakes but the ears on the clutch dog and forward gear were a little worn from slipping. After searching craigslist/ebay and shops for parts i was offered an old 72' evinrude 25hp for $200 (not near working condition). So after replacing the seals, i took the forward gear and clutch dog off the 72' and put on my 76' drive shaft. That was the easy part. I cannot get the lower unit to secure back right, there is always a 1/4" gap and when i go to tighten even farther the flywheel wont turn anymore. I seemed to get it tightened all the way once but there was no movement in the flywheel, could not pull start. The hub over the forward gear of the 72 and 76 seem the exact same size and fit either gear. i am stooped. Took apart lower unit probably 15 times yesterday. At the end of the day i felt like trying to break it over my knee like a golf club, so instead i drank a beer. any suggestions?
