Re: trim assembly from 98 optimax fit 84 black max?
I have only shown him mine, and he said it looks similar. I will of course have to see pics. If it is a two wire, can't that be remedied? When I bought my trim motor, some I saw were two wire, and said they had what was necessary to convert my setup to work with it. If the cartridge pump in his unit is the same, I could bolt it to my trim motor and use that in his working assembly.
I changed my trim motor, and after never could get the system to bleed. It would barely move up or down. And if I stood on the engine it almost worked correctly. I think I burnt the pump up trying and trying to get it to work while thinking it only needed to be bled. It seems a seal inside has gone to the bad. But inside the cylinder looks good, and I replaced those around the pump. I'm tired of chasing it, I don't know enough about it. I've wasted half the summer already.
His motor threw a rod, so he's selling for parts. I told him I'd exchange my trim assembly, so he could still sell the engine as a complete setup with repairable trim.
Is it certain the holes to bolt the ptt unit to my engine brackets will line up? I can drill more lol
