Motor was running great. Now starts fine, idles, give it throttle, ok.....get to 1500 rpms the engine bogs and stalls out. The engine will rev to higher rpms when not under load.
Cleaned carbs, checked fuel pump,stator was replaced a few years ago.
About to check timing, coils, and resistance on stator, etc. but not sure that will show much as one morning all was well, then the following morning, idling across the lake.
Any thoughts are appreciated.
