I just replace the water pump on my 1987 225 Evenrude and tested it and everything was great until I brought the boat back home from the lake and decided to change the gearcase oil. When I drained it there was more water then oil. I had noticed some oil leaking from one of the side drain holes when I was changing the water pump. guess I know why now. Changing the water pump was easy enough as no special tools were needed. Is replacing the seals pretty easy or is it time to take it to the shop. I'm pretty handy with tools but not a real mechanic.
Thanks,
Thanks,
