Re: Handrail condensation
The rails are bolted from below so taking them off is not an option.
Sure it is
Lift UP on the forward bolsters to unclip them .. or they Might have Christmas tree fasteners holding them on .. for some stupid reason on the outside chance..they Might have screws in the 'cording' of the bolsters.
They Do come off one way or another.
Sounds like a case of improper welding with the nuts to the rails. Or it could be rust coming from the end cut of the tubing going into a 'non drained' base.
You could try to Drill a hole in the bases ( 1/8"ish ) to let water drain out.
I hate those bases that are completely bedded or capped at the bottom.. then sleeve a tube into it. Where is the water gonna go ?
YD.
