Re: Hull repair
Fiberglass, aluminum, wood.......... what are the holes in?
You could use a marine epoxy stick and tear off a chunk, knead it and stuff it into the holes........
Back the holes on the underside with a small piece of fiberglass cloth and tape it there and fill the hole with resin from the top then use a gelcoat repair to hide them forever.....
In an aluminum hull you could have them welded up or use PC-11 or JB weld to fill them......
There are ways
