I just got a 3.0 gamefisher. I have not found any adjustment on the carb besides the idle screw.. Seems to be running real rich. Under a load it just seems to not run like it should. At WOT in the water if you pull the choke on it slowly just dies. I have completely takin the carb apart and cleaned. Also cleaned the take. Took pet **** off and replaced with a fuel shut off..any suggestions?
EDIT: YES. start your own thread instead of hijacking a 4 year old, dead thread.
I have done,
Cleaned tank,replaced fuel lines. Removed per **** and replaced with shut off valve. Removed and took carb apart and cleaned. Moved clip on the needle to the bottom then to the top. Clean fresh has. 50:1 mix. It sounds like a weedeater with too much line out. Only pushes me In a 14' flat bottom about 3 knots. I'm 180 #...
I have done,
