Coosa Composites.
tpenfield
Re: Coosa Composites.
The product gets mentioned here occaissionaly. I am not sure there has been a resto thread yet. It seems a bit pricey, so that is why you find most folks using wood.
Old Yeller Boater
I've not gotten any firm prices yet, but you could be right. One guy I talked to said he charges $500 a day plus materials. Another guy who does wood had given me a firm price of $800 for a transom replacement. that price was just the transom work and not including engine/outdrive removal and prep for the transom work.
benjh1028
I restored my 1995 Larson 214 LXI using all composites. Nida Bond for the stringers (pourable compound) and 1/2" Coosa Bluewater 20 on the deck. The Coosa is a bit pricier than wood, but considering you use less resin and cloth, the cost difference isn't extreme. However, I had a somewhat local source for the material so didn't have to pay for transportation (call Coosa and they can find you a local dealer). I forget the price/board, but believe my restoration project was only a few hundred dollars over the cost of using wood. This was well worth it in my mind as rot becomes a non-issue. Plus, there is the added benefit of reducing the weight.
Coosa is easier to work with than plywood. It cuts and shapes using conventional tools - although you will go through several jigsaw blades. I do advise wearing leather gloves when handling it as there are real tiny fiberglass particles created when cutting which can be quite irritating to the skin. I laminated both sides of the deck, however Coosa staff told me that typically only the walking surface needs to be glassed.
My only complaint is its ability to hold a screw. No problem adhering the deck to the stringers, but screwing the seats to the deck is a different story. What I did was epoxy stainless steel threaded inserts into the Coosa. This took some time, but worked well and allows for easy removal and put-back of all components attached to the deck.
If I can find some pictures I'll post them. Using Coosa (and Nida Bond), was definitely worth it to me.
Ben
Old Yeller Boater
thanks Ben. that kinda goes along with what my local guy said. he said he likes to glass a mounting plate (wood I assume) to the coosa for attaching seats.
Solittle
I had my 23' Wellcraft CC transom redone with coosa instead of ply some years ago. Kinda expensive but you never will have to do it again so worth the extra $. I was told that coosa is used for the transom core on off shore unlimited race boats but I did not verify this.
Old Yeller Boater
I just had the transom and rear floor repaired at a shop. He used wood for the floors, but happened to have some Penske board left over from a larger job, so used that for the transom. I'm very pleased!
