Hello everyone,
I am a novice when it comes to outboards so be kind. I recently bought a 1996 starcraft superfisherman 170 with a 1996 90hp force on it. I had the earmuffs on it and it started right up but when i turned the key to off position it didnt stop running. I had to pull the gas lines. I then checked the ignition wires and there was a burnt wire that i replace.( it was a solid black wire that was piggy backed off one of the original 6 wires. I tried it again and same exact results. Then I followed the black wire with yellow strip to the kill switch (whitch doesnt work either) and to the motor seemed to be fine i also pulled all the 6 wires and checked them and then replugged them back in. I tried to start the motor and now it doesnt even turn over. What did I do? PLEASE HELP
