I have a 1990 70 hp Mercury motor, I have changed the starter and plugs, cleaned the carbs, checked the compression which is 115, 113, 114. I have tried every proper starting with choke, start, wait, try again. Every combination of choke and none. Im at the point of lighting the motor on fire (which will not solve anything). Please give me as many things as you can think of to try. Im about to try draining the gas tank, cleaning it and trying new fuel. The fuel housing containing the filter fully fills when using the primer bulb (which also gets hard and isn't loosing suction). Please HELP!!!
