I have another thread on here that was originally related to the boat stalling in gear. I have started this on due to the other issues I have running the motor currently.
I have recently acquired a 1976 sea ray boat with a Mercruiser 888 ( Ford 351 ) engine installed. My first outing on the boat the engine ran like a dog. 2000rpm at WOT most of the day. With the engine cover removed it slowly crept up to about 2800rpm ( 30mph ) on my gauge. At the end of the day something let go in the motor mount and caused my drive to dis engage and I had to get a tow in.
Engine specs
Ford 351 windsor
Rochester 2bbl carb
Prestolite Distributor
OMC outdrive
The damage to the boat was repaired. Since I had the engine out I did the following.
New freeze plugs. New Valve cover gaskets. New spark plugs (NGK) , New distributor cap-rotor-points, New starter, Carb clean and new gasket set.
The Engine serial numbered showed it to be a Mercruiser 188 ( Ford 302 ) . I am not a Ford expert, nor would I know the difference between the 302 and 351. So under the assumption of it being a 302 firing order we set it with the 1542... firing order. The engine started and ran at what happened to be TDC on the exhaust stroke. ( Which was incorrect ) It did idle smooth, it revved out of the water to about 4000rpm. Under load it died. The timing was set at 10 BTDC. At the end of the day I gave up trying to run it and towed it home.
A compression test showed the following
Cylinder 1 - 95psi
Cylinder 2 - 100psi
Cylinder 3 - 95psi
Cylinder 4- 110psi
Cylinder 5 - 95 psi
Cylinder 6 - 0 psi
Cylinder 7 - 100 psi
Cylinder 8 - 110psi
So the dead cylinder 6 was an alarm. I pulled the valve covers and checked the firing order to find that it is in fact 137265.... Reset the order accordingly, cleaned the plugs and ran it again to watch the valves on cylinder 6. They do move up and down, no air comes out of them. The piston is moving as well at this point however it still showed 0 psi.
So cylinder 6 aside I was trying to get it to idle where it would hold a timing mark. Currently the timing mark jumps all over from 5* ATDC up to 15* BTDC. The engine idles between 800 and 1100rpm. When you give it any throttle it backfires and dies. Sometimes through the carb, sometimes through the exhaust.
So frustrated, I did a leakdown on cylinder 6. Filled it with about 40psi and listened for the air leak. Nothing out of the valve train, nothing out of the carb. So for ****s and giggles I threw the compression gauge back on it and cranked it over. It then showed 110psi on cylinder 6. I tested cylinder 2 as well and it was around 105psi. So the gauge is still working solid. I pulled the rest of the plugs and thew some marvels mystery oil in each cylinder for the night. I am going to blow them out in the morning and try it again.
My current distributor positioning is questionable. I have a photo of its current position with cylinder positions numbered on the top of the cap.
http://overtwocustoms.com/wp-content/uploads/dist-pic.jpg
Is it possible my entire distributor is 180* out? How about timing chain jumped and the entire engine is out of time?
I have spent countless hours on this project and I am running out of viable options. All help is appreciated.
Engine specs
Ford 351 windsor
Rochester 2bbl carb
OMC outdrive
Cylinder 1 - 95psi
Cylinder 2 - 100psi
Cylinder 3 - 95psi
Cylinder 4- 110psi
Cylinder 5 - 95 psi
Cylinder 6 - 0 psi
Cylinder 8 - 110psi
