Re: Thunderbolt 4 no spark Baffled
The boat was running fine on;y would backfire through the carb after 20 mins of cruising.
so I thought the coil was failing after it got hot so I changed that and motor ran very rough at start up.
so I changed the plugs and wires and rebuilt the carb, added fresh gas and fuel filters.Then when I tryed starting it ,no spark.
so I used the chart to test ign system and thought I had a bad module/amp,replaced that and dissconected the tach and shift cutout switch. used a ground from the battery and retested,still the only spark I get is from neg term on coil to center post.
Buying a new meter today to make sure I am getting a full 12v to coil, I had a cheap meter that was hard to read. Maybe I'm only getting 10 v to coil?
Pat
