chevcruiser
- Jul 25, 2012
- 5
I have a 1997 Bayliner Trophy with a 5.7 Mercruiser and Alpha outdrive. The trim cylinders seem to be stuck in the up position. I have removed the lines to the cylinders thinking they were hydraulically locked but had no luck. I also have been spraying the shafts and endcaps with pb blaster to lubricate the seals per previous posts and put downward tension on the outdrive but still no luck. This has just occurred in the last 3 weeks. Any help will be greatly appreciated!
