salmonslammer
- May 6, 2012
- 55
Not quite sure what I screwed up.....
Rebuilt the carbs, put it on the muffs....Fired right up. Ran it about 2 minutes and the alarm went off. Set the idle screw at the factory spec (1 1/8 turn out) so I know its not running lean. If anything, I'm running rich cause shes smoking more than it did.
I did drop a bolt down the leg and had to remove that... Had to use a rubber mallet to get the leg seated again.
Is it possible that I knocked the water pick up tube loose while banging on it?
Its an 88...85hp
Its an 88...85hp
