help - Tachometer for Nissan 4 Stroke?
cljack
I have a 2003 Nissan NSF 9.9B2 four stroke, i put the 15 hp carb on runs great but wanna make sure i am running right prop which i changed to a 10 pitch, the tachometer that use to be listed under the 9.9, 15, and 18 models is no longer avalible, is there another tach that will plug in the wiring harness like that one did? or any suggestions on another that i can retrofit and make work?
Sea Rider
Re: help - Tachometer for Nissan 4 Stroke?
For prop pitch wot test, you can install a Tiny Tach, Hardline tach. Installs in seconds as both are induction tachs.
Happy Boating
pvanv
Part# 3AC726400M $77.96
Tachometer with oil warning light (BLACK face). 4 inch diameter
Manufactured by Faria Instruments exclusively for Tohatsu. Gauge has a chrome bezel and is back-lit for easy viewing at night/dusk. Features a domed lens to minimize glare in direct sunlight and a fog & scratch resistant coating.
Fits all 4-stroke models and 40/50/60/70/90 2-stroke models with oil injection systems.
