MightyEsquilax
- Jul 15, 2012
- 32
Ok, I'm throwing in the towel here. The boat has run perfect at all speeds until late June. Upon going over 3200 RPM the engine begins to overheat past 190 deg and climbs steadily over the 200 deg range until I throttle back below 3200 RPM.
If I keep pushing the throtte the temp will continue to climb.
I pulled the boat out of the water and here are the following things I did.
1. Removed the exhaust elbows and verified no rust clogs (They looked brand new)
2. Removed the thermostat housing and replaced the thermostat (there was no thermostat in there...odd)
3. Replaced the lower unit water pump (impeller, gaskets, etc...)
After all this work I still have the same problem...
For what it's worth, the temp sender and temp gauge are brand new as of last October and *appear* to be working fine. My IR temp gun measures 140 deg at idle on the temp sender but I haven't checked the temp with the IR gun while it's overheating to verify yet.
My next experiment I think will be to put a clear hose in-line with the raw water pump to look for cavitation at 3200 RPM and above.
So my questions...
1. Should I be looking else where for a problem?
2. If I do find cavitation on the raw water pump line with the clear hose then where do I begin to start fixing that problem?
3. Can anyone give me the no kidding real ohms value range for the temp sender? I'd like to verify the sender and the gauge are correct. It seems every place I read has different ohms values for the temp sender...
Thanks!
So my questions...
Thanks!
