Hi, guys!
I just started working on a 1957 35HP Johnson Javelin (RJE-19). I bought the boat a couple of years ago and finally started getting it operational this summer. This is my first boat and outboard, but I am pretty handy working on mowers and other small engines.
I took the boat out for the first time a few weeks ago, and I noticed that it would regularly make a banging noise, and bounce up a bit, when I gave it around 1/3 throttle. I noticed that when shifted into forward, the cable wasn't fully pulling the gear shift knob on the motor forward. I adjusted the cable from the Johnson Shipmaster shift and throttle controller so that the shift knob on the engine was completely engaged in forward. This helped some, and I could give the engine a little more than half throttle before it would start the banging again.
The banging is quite regular, about two seconds between bangs at first, and the interval between bangs decreases as I give more throttle. I don't believe it to be a misfire, it seems too regular for that. At half throttle or lower, the engine runs very smooth.
I recently replaced all of the ignition components: two new coils, condensers, point sets, spark plug wires and spark plugs. I also took the carb apart, cleaned it, and installed a new needle and seat, as well as replacing all of the gaskets. Gas to oil is 25:1. I haven't done anything to the bottom end yet.
I figure the problem is that the forward gear is disengaging, but I'm not familiar with how the gearcase works in these old outboards. Is there a shift fork that could be bent, or something else that I could repair? Any other ideas?
Thanks!
Colin.
Thanks!
Colin.
