Can you interchange a force 85 hp prop shaft with another force prop shaft that is not a 85 hp ?
S SDH Recruit Joined Jul 19, 2012 Messages 3 Jul 24, 2012 #1 Can you interchange a force 85 hp prop shaft with another force prop shaft that is not a 85 hp ?
jerryjerry05 Supreme Mariner Joined May 7, 2008 Messages 17,926 Jul 25, 2012 #2 Re: 85 hp prop shaft Need way more info?? Year of the 85 and year and HP of the intended victum???
S SDH Recruit Joined Jul 19, 2012 Messages 3 Jul 26, 2012 #3 Re: 85 hp prop shaft 85 hp is a 1989 and it would be used on a 85 hp. thanks, I am sure I still need to give more info.
S SDH Recruit Joined Jul 19, 2012 Messages 3 Jul 26, 2012 #4 Re: 85 hp prop shaft i would get it from a 120 hp and year is not known by seller
