New to me boat (1993 Cobalt 220) 5.7L carbed Merc w/Alpha 1 ran great for about 4-5 trips before a progressively worse miss/backfire issue. Was also very cold natured at start up. I suspected ign module but started with a comp test and blew water out of #7. Net net had blown head gasket and a wet corroded ign module on the back of the distributor.
Heads off to reveal .040 pistons and a pretty fresh looking bottom end. Had heads surfaced, valve job, new 4bbl Marine Edlebrock carb and Davis Unified Marine HEI. Figured at this point I would cover all my bases with fresh fuel, and spark.
Engine started on first rotation after assembly. Never ever did that before
. Timing was 8* BTDC at 600rpm on the timing light. Then I noticed the dash tach showed 1200 rpm. Quick check on the back of the Faria gauge showed it was set to 8 cylinders. This gauge read correctly before the changes. Engine starts great, idles just fine but tach is off. Timing light with rpm read correctly on #1 wire.
This Dist set up only has two wires- a Batt wire the I connected to the old + Purple coil wire. A Tach wire that I connected to the shift interrupt and the old - Grey coil wire.
What would cause the tach reading to double?
