picked up a used 71 9.5hp, dont know how long it sat for.
since getting it, i have replaced, points set, both coils, j6c plugs, impeller, lower unit oil, starter rope....
it has good blue spark from the tester, and has 55psi compression in both cylenders.
it will start up for a second with pre-mix sprayed into the plug holes, and found it will rev up then promptly die when i spray pre-mix down the carb opening.
any ideas on what it might be? im thinking fuel problem, is it time to overhaul the carb?
any sugestions or idea on what it might be?
Thanks
Thanks
