I did a few searched on here and other forums to find any relevant help...I don?t have time to spend hours searching but my quick search turned up very little.
So here are the details on my OB:
7.5 HP Ted Williams Air Cooled Outboard
Chassis \ Model # 217-5889-0 (217.5889.0) Eska 1973
Serial # 3E-180996
SEARS ROEBUCK AND CO. U.S.A.
Engine Plate:
T-640-03B
TECUMsEH
6986531
This little motor came from my grandpa and has a lot of sentimental value...otherwise I would trash it and buy something else...which I may do anyway. But I like to tinker so this may be an easy and sorta fun project. The motor runs great. I rebuilt the card and it runs strong with no trouble. It has this habit of popping out of gear. When this happened I could fiddle with the shift lever and throttle and get it to go back into gear. It was annoying. After it popped out the last time I have not been able to get it back into gear. I pulled the prop off and got into the gears...the gear oil was gray and had some water in it. I cleaned it out and replaced the gear oil...not sure where the water is coming from. The seals look good, but I will watch that. The gears looked fine, no corrosion, and turned smoothly with slight resistance and no play. I found the shear pin in the prop had broken. I replaced that thinking that may be the problem. It was not. I am guessing it is something associated with the lever or clutch, etc. Any ideas? What to look for? I may tear into it this evening just for fun and to see what I find. Please help if you can. Thanks!
Serial # 3E-180996
Engine Plate:
T-640-03B
TECUMsEH
6986531
