5.8 OMC locked up
davleeren
The OMC 5.8 motor started fine 3-4 times on the water - anchored - tried to start to come home and the motor is locked up... no water or oil problem, no noise... just locked up. I took the Cobra outdrive off, turning the shaft causes the prop to turn (assume all is ok in the outdrive) -- but motor is locked up. I removed spark plugs... no water in cylinders. ??!
JON NEELEY
Re: 5.8 OMC locked up
Have you tried manually turning the motor with the plugs out? Assuming starter is fine?
davleeren
spark plugs out. no water in cylinders. teaspoon of oil in each cylinder. wait a day. motor still locked up both directions.
