gardengate
- Jun 25, 2011
- 9
The trim on my Four Winns 200H will not go up or down when using the switch on the throttle control. Back behind the engine on the transom there is a connection that goes to the trim. I have taken it apart and on the side going to the trim there are two flat metal blades. I connected two test wires to the blades and then hot wired to the battery to make the trim go up or down depending on the polarity of the connection. so the motor appears to be okay. The connection for the wires is large and rugged and snaps closed when you push it together. Even though it looks good, my guess is that the connection is not being made. I'm reluctant to mess with the blades to see if I can get the connection tighter because I don't want to break them. Has anyone had this problem before? Any ideas on how to fix it?
The engine is a Volvo Model 4.3 GXI-J with a Penta outdrive
