i replaced the original plug wires from the coils to the spark plugs and now it seems the flywheel is scrubbing against the edges of the coils, more noticable at low throttle where the engine will shake and stall out, was running fine before so i know its not a carburator issue or such, when i remove the flywheel you can see scrub marks against the outer edge of coils and inside the flywheel on magnetic plate. has anyone else had this issue? i also have the coils adjusted as far in on towards the crankshaft as they will go, please help if anyone has an answer i thankyou in advanceconfused:
