Re: 3.0 Litrer Oil pressure switch
I would suggest a oil pressure warning system to alert you instead.<br /><br />You really want your engine to die with out warning, could cost you your life.<br /><br />What if you approching a bridge down stream in a swift current river? What if your approching a tanker in a narrow channel? What if your in a sea with breaking swells?<br /><br />Do you really want your motor to shut off and not restart then hit the bridge, be run over by the tanker or capsize in the sea.<br /><br />Personaly I would rather burn a bearing at low speed than loose my boat family and life at a danerous time to have no power.<br /><br />Alert me of low oil pressure and I will decide if it safe to shut the engine off. After all at idle engine will run a long time with very little or no dammage even with no oil.<br /><br />I know a drunk who stopped at a bar and ran over a concreat parking curb. It ripped the oil plug out of the bottom of the pan and all the oil ran out. He had a drink then drove it home over 40 miles at 55 miles per hour. I help him repair the pan and put in a new plug. He keep the car for 5 years after that and it ran good with good. It was late at night and winter but I could not belive it made it that far with no noticeable damage but it did. He was not useing any kind of Special oil either.
