+1. Hi Tyler. Welcome to iboats. Steelspike is right. The motor's height and trim adjustments can make a huge difference in performance, as well as proper weight distribution. You may want to try rearranging the layout of the boat, such as putting batteries and/or fuel tanks closer to the bow to help more evenly distribute the load. If the boat has/had any wooden components (decks benches, etc...) be sure that they're dry and not waterlogged causing the boat to weigh more than it should either. You can also use yourself as ballast and move farther forward int the boat my using a tiller extender, or installing a helm. I made a great little tiller extender for my '66 20 hp from 1 1/4" thin-walled PVC. You just cut it to length, add a few slits to one end, drill and slip it over the stock tiller and secure it in place with a couple pip clamps and voila. You can now sit, or stand, more towards the center of the boat which should help even the weight out a bit too. It also takes the strain off of your shoulder caused by reaching back to grab the stock tiller all day. It should also make steering much easier. They make fancy carbon fiber versions, but mine was only about $2 and works like a charm. Unfortunately, there's no real formula to finding the best set up. You just have to spend a day on the water doing lots of trial and error until you find what works best for you. Good luck. Keep us posted.
View attachment 159913View attachment 159915View attachment 159912
