Attempting a water pump replacement in a 1997 DT140, and everything was so corroded I damaged the drive shaft housing underneath the water pump removing all the sheared / corroded bolts. The main piece of assembly #26 here:
http://store.brownspoint.com/dt140/fig020-1408601.asp
How the heck do I get this piece out? Does the driveshaft need to come out first, or should it release and slip up and off the driveshaft?
Thanks in advance, considering bringing this to a shop as I'm reaching the limits of my ability (or patience...)
