Video of my engine acting up. Please help! Tried everything!
197935hpjohnson
http://www.youtube.com/watch?v=S8x-SExDuW8&feature=plcp Here is what its doing.
Things ive done/checked are as follows:
1: Compression 120psi on both cylinders
2: New plugs
3: Disassembled, cleaned, inspected and reassembled carburetor. (It was perfect inside)
4: New fuel lines
5: Verified timing is opening all the way and carburetor is opening fully under full throttle.
6: New fuel, tanks
7:Disassembled fuel pump, inspected and reassembled (Everything looked good)
8: Checked all wiring for corrosion/loose connections
9 Verified both cylinders are firing (But have not done spark gap test)
I just dont know what else to do, please if someone could help me i would be GREATLY appreciated.... It just simply has NO power and wont rev under a load. However, if put muffs on it, or in a test tank it will rev out like its supposed to. Just not under a load.
P.S. Pumping the primer bulb does not make a difference, so i "think" ive ruled out a bad fuel pump.
1946Zephyr
Re: Video of my engine acting up. Please help! Tried everything!
I love number 7 You missed your space bar and got a Smiley :D
I would check your coils over and make sure they're not cracked. If you have antique coils, then they will need to be replaced. It would be good to replace the spark plug leads at the same time, if you do coils.
boobie
Get a squrit can of premiix fuel, take the air box cover off and run it. When it surges, squirt some fuel in the carb throat and see what happens. If it picks up and runs go over your fuel system again.
Higgins79
Hey. My 79 Evinrude does something similar. Today I found that the previous owner had use a "universal" gas line from the tank. I tossed it (it wasn't in good shape) and got one fitted for OMC. The motor really wasn't getting much fuel with that old line. This is just a baby step and I hope there's nothing worse wrong with it, but please message me if you find the problem with yours.
AlTn
seems to me you can hear the rpms increase dramatically as long as you are squeezing the primer bulb every few seconds...is this the case?...is the vent fully open on the tank?...that surging often indicates air entering the fuel supply somewhere
1946Zephyr
Yea, that sounds like a fuel delivery issue, now that I saw the video. You might also check and make sure you don't have a weak fuel pump too.
197935hpjohnson
Hey guys thanks for the replies. I took it to a boat marina today and he had me back it down the ramp and spray a bit of carb cleaner in the carb as it was bogging. He said if the R's pick up its def a fuel issue. Sure enough, it picked up. So he had me pull my carb. We took it inside and he disassembled it for the 6th time (At least) and said "Its super clean inside here" So he started putting it back together. He grabbed the bowl and went to put it on and said "Wait a minute, isnt there supposed to be a rubber washer on here?" I said "Rubber washer?" So he went and grabbed a carb kit for my carb and sure enough i had lost a rubber washer that makes a seal against the idle circuit and bowl. So he put it in, reassembled my carb and she runs GREAT now!!. All this time and it was my fault because i lost a rubber washer by accident while taking the carb apart to inspect it. He charged me 29.99 for the kit and 10$ in labor even though we worked on it for a good 45 minutes. Old timers are the best mechanics! Thank god for him i would have never suspected it.
197935hpjohnson
Sorry for the double post here is a picture of the washer i was missing
Higgins79
Wow! If you get a chance can you post a vid of your "new and improved" motor? I'd like to see how she runs so maybe I can hope and pray that's what mine will be like :p Also what kind of boat does it run on?
boobie
Check post # 3 again.
197935hpjohnson
You the man boobie! Exactly what my mechanic told me to do also. I would have done that myself, but since id had the carb apart so many times, i was 100% sure it was correct! Ive never seen a rubber washer like this in any small engine carb ive rebuilt/cleaned and ive done 100's! Just not boats! Next time ill know.
Edit* Yes, i will get a new video probably this weekend of the new and improved engine! It's running on a 16ft landau flat bottom. Good fishing boat :)
boobie
As I always say, " it's the little things that will get 'ya "
scipper77
Mine had that gasket rot away due to ethanol. I was having similar issues, I took the carb apart and it was super clean as well except for the crusty o-ring and the bits of rubber in the bowl. I ended up getting a viton oring (after a member here told me what size o-ring I could use as a sub for the one in the carb kit). My motor now runs great just as was the case with yours.
I tell you carbs are such finicky little things. If everything isn't just the way it should be it can sure make the motor do some crazy things.
