I have twin 1988 Yamaha 200s on a Boston Whaler Outrage. Went for a quick ride today and the port motor would not raise when we went to anchor either by the main trim switch or the individual trim switch, although it just worked when we left the dock. The trim on the starboard motor works fine w/either switch. I have had pump seals replaced in the past but I've never had this type of trim problem. It appears to be electrical as there is no noise whatsoever when the switch is activated. What should I check first?
