havoc_squad
- Mar 5, 2011
- 704
I have a 1993 Mercruiser 3.0L that I've been fighting for off an on for a while involving a hard start and at idle sometime dies systematically.
Info update:
Fuel pump failed: Replaced in April
Ran rough at idle all the time and was difficult to start: Carb rebuilt.
When it would idle, it would idle normal. However very difficult to start warm: Service shop lake tested, the adjusted float level for free to resolve it.
Now:
Idles better and dies less often but the hard starting still appears at random intervals and I hear sprattic random popping through carb at times. Generally occurs most when slight throttle from starting to running transition, OR when I shove the throttle down for a fast WOT start.
Also, now I believe most of the issues where it dies ends up shortly after a hard start.
Also, the float adjustment seems to have made my hole shot a bit longer too.
Notes Found on lake test:
I've noticed when I have the hard start issues. A time or two I seen the voltage drop to 12 volts or about 10.5 after the engine caught up and was at idle speed. I don't remember seeing this consistently, but it was there. I would notice the voltage would drop before the RPM's would drop to about 10 volts. Then it would stumble and gave it 1500 rpm's of gas, but it would hover near 12 volts or less then.
Tachometer at times would report correctly, other times it would be completely wrong. I've heard this can possible end up being a coil issue.
The ignition coil was normal temperature. However, the altenator was a little bit more warm than expected. It was not too far from the temperature of the engine block. No noise and most of the time I remember seeing near 13 volts most of the time on the dash guage.
I have the service manual, but could someone repeat the testing criteria for the ignition coil module to see if it is defective?
I believe carb/fuel related has been investigated to its death and ignition needs to be verified. I have some very hard to find gremlins that are well disguised, and its getting to be a real pain.
Info update:
Now:
