Re: Need New Engine!!!!
Me too, I need a new engine.
Do you want a cheap engine or a good engine? I'm not sure that those come from the same place . . .
If you upgrade by doing a V8 long block, you will need the intake manifold, exhaust manifolds, perhaps the water, pump, etc.
Usually, long blocks are meant to replace the same size engine, so pretty much everything from the old engine can be swapped. You may get $100 to death doing a long block upgrade.
