I have an evinrude 90 hp 60 degree 99 year model. The engine will not tilt up while the shifter is in gear. It will work fine while in neutral and works at the engine while in gear, but not at the control box. Any thoughts? It is not the motor or pump, the relays seem to be working fine. I was wondering about the tilt limiter switch also there is a sensor on the front of the engine at the steering tube, not sure what that is for. Let me know what you think.
Thanks
Thanks
