I have a 2004 mercruiser 3.0 l that shut down as a result of low oil. I was wondering if the engine has a low oil shut down? Also i haven't try to start it since so was wondering if it would be ok to try.
I put some oil in and attemped to start it. The engine turned over fine and sounded fine. The engine mad an attempt to start but never. There was no bad noice. Just wondering what i should do next or just tear it apart.
thanks in advance
How long has it been since it ran? Gas evaporates.
You might have to turn it over a few times for the fuel pump to refill the carb.
Also, did you give the throttle a couple quick pumps while turning it over?
It was only one day after the engine shut down that i tried to restart it. I let it turn over for quite a while and yes i gave the throtle a few pumps. It made a coule of small attempts but just never caught. Is there anything else i should try?
