fuel pump question
phockeye
have a 1990 120 hp evinrude, VRO is disconnected I'm told a substitute can be used when replacing the fuel pump the question is which fuel pump should be used? anyone out there who has done this ?
Chris1956
Re: fuel pump question
The Maxrules website will recommend a fuel pump for that model. You may use the VRO pump to pump premix fuel as well, if it still pumps
boobie
You can also get rebuild kits for the fuel side of the vro from Maxrules.
phockeye
a 2 pump system is indicated for v4 motors (they did this on some commercial units) problem is my crank case only has 1 vacuum port, I'm thinking there must be a snowmobile fuel pump or something that would provide adequate delivery
